home Engineering ToolBox
Apps
Calculators for online and offline use! Update offline cache with a Hard Reload!
Heat Recovery Calculator
Sensible Heat Recovery
The calculator below can be used to calculate the sensible heat recovery where the air flow, outside and inside temperature and recovery efficiency are known.
air flow (cfm)
t1 (oF)
t2 (oF)
recovery efficiency
t1 - outside air temperature before the heat exchanger
t 2 - outside air temperature after the heat exchanger
Total Heat Recovery
The calculator below can be used to calculate total (latent and sensible) heat recovery where the air flow, enthalpy of outside and inside air and the recovery efficiency are known.
air flow (cfm)
h2 (Btu/lb)
h1 (Btu/lb)
recovery unit efficiency
h2 - enthalpy outside air before the heat recovery unit (Btu/lb)
h 1 - enthalpy outside air after the heat recovery unit (Btu/lb)
Powered by
Engineering ToolBox
engineeringtoolbox.com
tools, information and data
No installation required!!
Just visit the Calculator app in your browser, and - if you want - bookmark the Calculator app in your iPhone, iPad or Android browser - or add a link to your
Home Screen
Calculator apps visited online are saved in the browser and works offline!
QR Code
QR
apps.engineeringtoolbox.com
the Engineering ToolBox Privacy Policy
10 16
